How slow can it go?
Pretty darn slow. My 811B in 1st gear, Caseomatic locked in and idled down just creeps along like an old lady with a walker.
With the Case-O-Matic tranny the range of speed is O to Max per gear. Applied throttle against load. with a constant load, speed will be very easy to control with the throttle. but if the load varies you will have to vary engine rpms to control speed. If you can travel fast enough to lock it into direct drive, the engine govenor will control your speed. How slow do you want to go?
I've never done it but always thought a C-O-M would be a winner in Slowest Tractor Contest with it at idle in low gear C-O-M and ride the brake to barrrrrelllyyyy move....
I grew up on cases but now have an 1800 oliver gas that is way slower than my 50 john deere that is a little slower the my competitor racers 400 case diesel and it is in good shape
