drsportster
How thick can a mid-range priced plasma cutter cut My [job is one inch thick which I suspect can only be done on a large expensive unit .
What are the dollar amounts of your "mid-range" price? Price and severing capacity don't necessarily run hand in hand. Higher quality brand name ones in the "mid-range" may not have as thick of severing rating as a lower quality one of the same mid-range price. You need to compare the ones you find in the price range you have in mind.How thick can a mid-range priced plasma cutter cut My [job is one inch thick which I suspect can only be done on a large expensive unit .
I would think that's the simplest option.I was going to go to my local welding shop and have them do it
85 to 90 amps can do it. Quality is really important HyperTherm, and other name brands are recommended for reliable use. and continued supply of consumables. Very dry air is also crucial for consumable cost savings. Refrigeration condensing dryers are best. JimHow thick can a mid-range priced plasma cutter cut My [job is one inch thick which I suspect can only be done on a large expensive unit .
I have my typical rant about plasma cutters.......................too tired to do it tonite. But..........I despise how they're marketed in terms of thickness of cut. Always to the high side............never an honest figure. I can sever a 3" piece of plate with the rosebud I have.........simply by melting it........but that ain't a "cut", and you're a liar if you call it so.I have a miller 625 it is rated at 5/8 quality and sever 3/4. It would not cut 1 inch.
If cutting torch would not yield the quality you need, I would take it to a welding shop, they may even have a Lazer, or water jet.
farmersamm is right about the severing thickness, I should have said 1" clean cut, which is less than one will sever.I was going to go to my local welding shop and have them do it
I don't do enough to have a tank for a torch. $100 a year rent is to much when it takes 3 years to empty. I have a 42 plasma. works up to 1/2 inch but that is slow. 1/4 works great. i use grinders and chop saw a lot. cut off wheels work good in the right place. I some times miss the torch for heating and bending stuff but not very often. I paid $500 brand new but second hand for my plasma.I've wanted one for a few years now but keep hearing the same thing the thicker the slower and less likely it is to do it without going to a big expensive model for the 3/4-1-1/2 stuff. If I can't cut close to an inch thick decent then I guess I will stick with the torch for it. And use the grinder with a cutoff wheel for the thinner stuff and have clean pretty much no clean up edges for welding.
See if your LWS sells owner bottles. Around here, owner bottles are the smaller 150cf variety. I believe I paid in the neighborhood of around 200 clams apiece for mine. I've got 3 of them due to the amount of cutting, and heating, I do. Costs about $12 plus hazmat to fill them. I have my own Acetylene bottle, and 2 Propylene bottles for Propane.I don't do enough to have a tank for a torch. $100 a year rent is to much when it takes 3 years to empty. I have a 42 plasma. works up to 1/2 inch but that is slow. 1/4 works great. i use grinders and chop saw a lot. cut off wheels work good in the right place. I some times miss the torch for heating and bending stuff but not very often. I paid $500 brand new but second hand for my plasma.
fill on oxygen was $65 when I last bought. Buy your own are about 16 inches tall and not cheap. My dad had one of those and had a hard time finding anyone to fill them. never could understand why they cost so much. I did hear some people went to the states to get buy your own and get them filled. I think my dad had to drive 2 hours from home to get it filled. I know guys in Alberta almost all own there own, but can fill up everywhere.See if your LWS sells owner bottles. Around here, owner bottles are the smaller 150cf variety. I believe I paid in the neighborhood of around 200 clams apiece for mine. I've got 3 of them due to the amount of cutting, and heating, I do. Costs about $12 plus hazmat to fill them. I have my own Acetylene bottle, and 2 Propylene bottles for Propane.
I've had my bottles for near on 30yrs...................you can imagine how much rent I've saved in that time, plus the convenience.
Owner bottles are swapped out, same as rentals, when you get a refill. They don't stand there and refill them. If you do buy bottles, make sure the ring on the neck either says "owner", or says nothing. You can't exchange any bottle that has a company name on it........it's assumed to have been stolen. Keep your invoice...........this is 'title" to the bottle, and enables you to fill it anywhere.........or sell it if you please.
Probably argon or CO2 instead of oxygen. Putting more fuel on that plasma cutting flame will just melt your steel, I think. Not to mention the possible ball of flame when the cut is started. Air comes on slightly before the arc starts.Most small shops now use oxygen because it's
Well, I saw tanks being used with plazma were I buy steel and assumed oxygen, my bad.Probably argon or CO2 instead of oxygen. Putting more fuel on that plasma cutting flame will just melt your steel, I think. Not to mention the possible ball of flame when the cut is started. Air comes on slightly before the arc starts.
I'm not so sure about that, GOOGLE "oxygen or CO2 for plasma cutter" for some enlightenment.Probably argon or CO2 instead of oxygen. Putting more fuel on that plasma cutting flame will just melt your steel, I think. Not to mention the possible ball of flame when the cut is started. Air comes on slightly before the arc starts.
