how to hook up loader on int.b 414
ben horn
how to hook up line for bucket to tractor were does it go i have an int b414 does it hook to the valve under seat there is a shut off valve and a slow down and fast valve with to plugs in it under front of seat does it hook into it and can i run it using my 3 pt lever
No, you can't run it with the 3pt lever. That is for the 3pt hitch.
Your tractor should have one or possibly two hydraulic remote valves on it somewhere. I am not familiar with the B414, so you're either going to have to find someone who is to tell you where they are, or get yourself an owner's manual and look it up.
Normally, hydraulic remotes will have quick-connect sockets on the rear of the tractor, arranged in pairs. There will be levers to control them on the right side of the driver's seat, or on the right side of the dash board. These will be different levers from the 3pt hitch controls.
Hi Ben, the B414 remote outlet that can be controlled by 3pt lever is only single action and a loader bucket requires a double acting cylinder. The proper way to hook up a loader on a B414 is to buy a set of hydraulic control valves, mount then on the loader frame by the right side of the steering wheel. Cut a section out of the high pressure line from the hydraulic pump and connect this line to inlet of hydraulic control valves, connected outlet of hydraulic control valves to remaining section of the high pressure line that goes to the hydraulic reservoir under the seat. If the hydraulic control valves have a low pressure dump line connect this line into the hydraulic filler plug behind the seat.
JimB
Actually you can run a loader with the 3pt lever on those IH's, just like JimB2 stated, single action only, manual trip bucket. I've driven a 276 with a 1501 loader equipped as such new from the dealership. the 3pt isn't usable at the same time so it's not as handy as the "proper" way with the valve piped in. The run off the 3 pt lever was a cheap way to run the loader, just not practical today for a new installation.
THIS IS A HAND TRIP BUCKET SO CAN I HOOK THIS INTO THE VALVE UNDER THE SEAT IT HAS A SHUT OFF AND A SLOW FAST VALVE ON IT WITH 2 PLUGS IN IT 1 HAS A SCREEN ATACTHED AND 1 DOSENT CAN I HOOK DIRECTLY TO ONE OF THESE TO RUN LIFT FOR LOADER AND CAN I USE THE 3 PT LEVER OR THE ONE NEXT TO IT TO RUN IT
