How to remove a cozy cab
KJH
Hello
I have just sold a cozy cab off my john deere and im going to remove it. The guy who bought it is going to help but I have never taken one off before any advice would help. It has two hooks on top so I will put the loader tractor on the hooks with a chain but others talk take bolts out back and just rock it off? Which is the best and any advice.
Used chain falls in 12' ceiling shop between the trusses. To tight.
Have made plywood box since for cabs removal (3). Go's on skid-steer pallet forks, drive box into cab's open window (removed glass), pick up cab. This our simplest easiest way to coming or going.
Fernan
Lift it straight up!make sure your loader can lift high enough(most smaller/mid size will not).Make sure your loader has enough capacity to handle the load.Above all,be carefull!and dont get under the thing-$h!+ happens.
