How to take apart
Old560
Any one know how to take the chrome bezel off the front? There?s one screw that goes in the back of the assembly but that doesn?t release the bezel. If photo loads.
They often use a similar approach to tires on rims, A lip on the housing is a bit larger than the bezel lip. Careful application of thin dull screw drivers to gently work it off. Telling us what it is will help those what might have experience with it. Jim
Post a picture of your Power Wagon, we'd like to have a look at it. They were the real McCoy, that's for sure, I see a lot of them getting BIG dollars at some of the big auctions.
Usually...........................
remove screw, pull away from housing at screw hole, pushing ring up as you pull.
The ring has a tab going down into a slot in the housing, opposite where the screw was.
Usually.
