Gord William
Hi Folks,
I have a Howard Rotovator Tractor Attachment I am wanting to run with my 1954 TEA tractor but I have some questions and I would appreciate any feedback or experience anyone reading this has. The Rotovator is a centred, not offset and has a 1 3/16 square drive pto shaft but no matching tractor tube for the tractor. So I attached the Rotovator to my tractor to get some driveshaft dimensions (it's a 4 point hook up not a regular 3 point hitch.) Anyway I will have to make up some new brackets that attach the Rotovator arms to the bottom side of the tractor axle, (one on each side and close to being under the fender mount). The original brackets don't match all that well and it seems the ears on them are not long enough to allow proper mounting. They interfere and don't sit proper not to mention the Rotovator sits a 1/2 away from the tires and the tire tread is almost non- existent. The drive shaft which is about 7 inchs long also touchs the end of the tractor pto shaft and I don't yet have the tube or yoke or cross bearing in place. I think the Rotovator needs to be at least another foot away to allow new brackets and the new driveshaft. The lift arm swinging brackets on the Rotovator look like I could maybe move out another 8 or 10 inches. I can make up the needed brackets to move the Rotovator out 8 or 10 or 12 inches but I'm wondering if this is proper or how can I make up a shorter drive shaft without cutting the original square shaft. I'm pretty sure the tractor and Rotovator are close in age and my tractor does have the proper gear reduction so what am I missing? I've looked at pictures and the Rotovators appear to run very close to the tires but mine is way to close. Maybe the end brackets on the arms aren't orginal or perhaps they were for a different tractor of the day. I will try and load pictures. Thanks
Gord
Gord
