Howard yransmission, again...
Ed-8N
This message is a reply to an archived post by TheOldHokie on June 12, 2018 at 17:06:49.
The original subject was "Re: Howard yransmission, again...".
Message to TheOldHokie: Have you got any further with the planetary reduction unit?
(quoted from post at 16:12:23 05/02/20) This message is a reply to an archived post by TheOldHokie on June 12, 2018 at 17:06:49.
I really don't have time to work on it but I did steal some to tackle the issue that had been holding me back - machining the pockets in the carrier for the planet gears. I only have 5 pieces and I didn't want to turn one into unusable scrap. As it turns out it was only mildly exciting - I busted my milling cutter on the first go round but learned my lesson and got all four pockets cut with the replacement. Encouraged by that I also machined the sun gear for a pilot bearing and did a little detail work on the intermediate shaft.
Once those hurdles were cleared I got to test the fit in the annulus and as expected it needs some tweaking. I initially designed all of the gearing with "standard" center distances and had them machined with standard pitch diameters. I later realized that in a planetary system that doesn't work - something has to be undersize/oversize to allow for gear lash and running clearance. As you can see from the second picture the carrier and planets won't quite drop into the annulus. I can get it in with some work but it is way to tight to operate properly. I have known I had this problem for some time and after MUCH thought and study of the gear cutting section of Machinery's Handbook I decided the solution was to make the planets slightly undersize. So next up is to cut four new "profile shifted" planets where the entire tooth profile and OD is moved inward .007 or so. If I understand the gear cutting theory correctly that produces a slightly thinned tooth on a reduced OD which provides the needed gear lash and tip clearance. That will also give me some wiggle room for a reasonable manufacturing tolerance when drilling and reaming the gear shaft bores in the carrier.
While I was playing hooky from the things I should have been doing I put together a little YouTube video explaining the operation of the gear box.. The first part of the video describes the repair I had to do on the tool holder I busted along with the cutter and you can skip over it to get to the theory of operation part:
How It Works
If the profile shifted gears work as expected and I don't botch the machining for the planet gear shafts the rest is pretty easy. I am beggining to see the light at the end of the Prototype #1 tunnel.
TOH
(quoted from post at 10:18:31 05/03/20)
Been hoping to see more progress on this project
and I too will say pretty slick !!!.............. 8)
Frankly I had pretty much abandoned it when my gear shop "partner" went out of business. Then a few months back I got a motivational speech that got me re-energized :roll: I have so much work backed up it's hard to find time to work on it but at this point I'm sure at least one WILL get built. How well it works after its built is the $2000 question :wink:
TOH
