(quoted from post at 17:31:14 06/21/18) Is there any difference in power between a 50 hp gas and a 50hp diesel?
(quoted from post at 20:05:42 06/21/18) As I understand it, a diesel has 20% more real hp than a gas engine rated with same hp. Ed Will Oliver BC
(quoted from post at 23:01:01 06/21/18) Depends a lot on what engines you are referring to. Comparing same size and make tractor engines, actual power produced will be near equal. No one will ever be able to prove to me, however, that a "250hp Yamaha outboard" : or a 250hp 283 Chevy will pull what a 250hp Cummins diesel will. ( Cummins 855ci naturally aspirated mechanical engine)
(quoted from post at 20:01:01 06/21/18) Depends a lot on what engines you are referring to. Comparing same size and make tractor engines, actual power produced will be near equal. No one will ever be able to prove to me, however, that a "250hp Yamaha outboard" : or a 250hp 283 Chevy will pull what a 250hp Cummins diesel will. ( Cummins 855ci naturally aspirated mechanical engine)
The 250hp Chevy and a 250hp Cummins, both with 1 to 1 direct drive transmission, will result in vastly different outcomes.
(quoted from post at 07:22:08 06/22/18) "There in lies my point. The 250hp
outcomes."
- Yes indeed the outcomes would be much different. Running without a transmission would have only the rear end reduction. This would be an improper application and none of the engines would be effective to it's potential.
"Horsepower is supposed to
be a statistic at the flywheel. Not
as a result of gearing and
transmissions. When in vocational
school, I also was told the
mathematical formula that was
supposed to be used as to calculate
horsepower. I stand by my statement.
This day and time, seems that
horsepower ratings are based on
whatever formula the builder wants to
use."
- The formula is: HP = Torque x RPM / 5252. It is the result of the engine output and does not change with gearing. Included in my post was the AGT 1500 HP after the 10:1 reduction and the HP ahead of the 10:1 reduction, i.e. at the engine output shaft. The gear reduction increases the torque and reduces the RPM however, HP remains the same. For the formula, the RPM is the RPM of the shaft where the torque is measured.
(quoted from post at 09:56:52 06/22/18) I am certainly no expert on HP, but it seems 2 things are getting confused. Seems it comes down to the age old question. What is heavier....15 pounds of lead, or 15 pounds of cotton?
(quoted from post at 11:11:18 06/22/18)(quoted from post at 17:31:14 06/21/18) Is there any difference in power between a 50 hp gas and a 50hp diesel?
Main difference is the rpm the 50 HP is obtained at.
With a diesel you will typically reach peak HP at a lower more useable rpm than the gas engine.
For example if the gas engine reaches its 50 HP at 4000 rpm and the diesel does it at 2000 rpm assuming both tractors have the same gearing and tire size the diesel will deliver more pulling power coming off idle and accelerating up to operating speed.
(quoted from post at 08:02:11 06/22/18) The difference in combustion speed between gasoline and diesel fuel has an effect on torque. Gasoline burns almost completely with a quick expansion of combustion gasses when the piston is at the top of the power stroke. Diesel fuel continues to burn and expand the whole time the piston is on the way down on the power stroke. This gives the gas engine quicker acceleration than diesel but the diesel has more torque from the longer burn time.
(quoted from post at 20:04:14 06/22/18)(quoted from post at 11:11:18 06/22/18)(quoted from post at 17:31:14 06/21/18) Is there any difference in power between a 50 hp gas and a 50hp diesel?
Please explain tractors that were available with gasoline or Diesel engines . The 4020 JD for example made the same power at the same rpm.
(quoted from post at 23:51:44 06/22/18)(quoted from post at 20:04:14 06/22/18)(quoted from post at 11:11:18 06/22/18)(quoted from post at 17:31:14 06/21/18) Is there any difference in power between a 50 hp gas and a 50hp diesel?
You can de-rate any engine to produce a lower than potential chosen HP.
At times this has merit as the longevity is increased.
Unfortunately running an engine at such a reduced efficiency will cost you dearly in fuel consumption.
Gas engines typically reach peak HP at higher rpm than diesel engines so all you are doing is holding it back from it's potential and wasting fuel.
The 8.1 Vortec in my dually for example makes about 150 HP at 2000 rpm by the time it reaches 4000 rpm it peaks around 340 HP properly geared and utilized it makes a lot more sense to use the power it can dependably make instead of governing it at 150 HP.
Limiting factor on a tractor is being able to use the same transmission and gearing for gas or diesel and still maintain a 540 or 1000 rpm at the PTO.
