Hub replacement on Farmall SM
I?m looking to replace the traditional Farmall front hubs and rims on my SM with a 5 or 6 bolt pattern hub and pressed steel rim without changing the whole bolster. Can anyone tell me what size hub and bearing will fit the current spindle?
My super-M came to me with a 460-560 front axle and rims -- looks like it bolts right up with the 4 bolts underneath --easy weight reduction -- Roy
On a couple that I did I found hubs off other tractors, 30 MH, etc, then measured up the spindles and races, took those measurements to the parts man or bearing house and mounted those hubs up to my tractor. That kind of stuff was some of my fun of tractor pulling. gm
