Huber LC Starter
J Tierney
Does anyone have a starter, or the number off of their starter on an LC Huber, or other model that may fit? Thanks in advance
Try looking under Engine maker, and model,rather
than tractor model. I've seen Hubers with
Chrysler Industrial engines. Did any use Hercules,or Contenental, or Waukasha ?? Just
suggesting because Huber, mostly purchased
engines from others.
Huber listings in my old parts catalogs don't agree, but two do show various Wauks:
38 Victor gaskets: L, LC, 1937 Wauk VIS, VIL (catalog lumps these L's in with others, so don't know if LC had either engine or just one of them)...
52 McCord tractor gaskets: Huber LC 1937-44 Wauk VIK/VIL (this listing was a separate listing of the LC's, so may've been engine options or an upgrade). One reason for the discepancy may've been engine changes during production run.
If a Wauk, should have tag on side of block with engine model and ser #. Wauk Eng Hist Soc (wehs.me.com) should be able to tell what starter came on yours. If no tag, find all cast/stamped numbers before emiling. They're all volunteer, so may not reply immediately. They have manuals but no parts. Good luck.
Forgot I"d recently gotten:
1950 Fitzgerald gasket: L,LC 37-44 Wauk VIS/VIL (this also lumped with other Hubers);
1963 McCord gasket: two entries for LC, 31-45, Wauk VIK and VIS, as if either engine an option.
Both the VIK and VIS were listed for other Huber models.
Also forgot to mention the Huber club should be able to advise sources or what will work.
