Hubs info for Ac-B,C,Ca
J88puller
Can someone please tell me the bearing size as for as the axle shaft I guess you might call it for a C,Ca and a model B I guess they all use the same hub but i need to know the bearing size. Thanks
Rear Axle/Final Drive:
--the "axle is normally refered to as the top shaft that has the brake drum and splines into the bevel gear behind the transmission.
--the lower shaft with the wheel is normally refered to as the "bull shaft".
Axle Seal- CR #25043
Axle Speedi-Sleeve - CR #99248
Outer Axle Bearing Cone - Timken #368A
Outer Axle Bearing Cup - Timken #362
Inner Axle Bearing Cone - Timken #14138A
Inner Axle Bearing Cup - Timken #14276
Bull Pinion Seal: CR #13900, National #450456
Bull Pinion Bearing Cone - Timken #14138A
Bull Pinion Bearing Cup - Timken #14276
Thank you for taking the time to look it up but it appears that I did not mention it was the bearing hubs for the front wheels that I am needing the size for.
