Hudson hand sprayer nozzle question
I have a 2 gallon hand held pump sprayer. It has the brass round tip that sprays in a cone shape. I'm searching for a spray end that has a flat spray tip like used on field sprayers for a more direct spray and a flat spray patttern. Does anyone know if anything like this exists or could one be made from a sprayer drip nozzle? Any assistance is always appreciated.
It's been a long time but I used to spend my days at work solving this kind of stuff.
My memory of part numbers may be a little off but close,maybe.
See if you can unscrew the noz. assy and have the wand with a threaded end left. Take
a Spraying System nozzle body,it s either a 1321-1/4tt or a 1322-14tt. Anyway,the one
with female threads on one end and standard nozzle male threads on the other. Then you
can get a Spraying Sys nozzl cap #1325br or 8027ny and an 80degree flat fan tip.
Hope this is close enough to get on the right path.
2 Gal sprayer "Roundup" brand. Has the round adjustable tip, and the sprayer type with two different nozzles. All for $10. I don't know about others but I keep 4 handheld sprayers for the four different pesticides I use around the place on the garden, lawn and trees. Went to that after killing a few plants due to contamination.
I slipped and fell on a steep hillside and broke the wand on my pump-up sprayer. I replaced it with a new wand like used on 12 volt tank sprayers, and it worked so good I also changed the wand on my garden sprayer. New soft flex hose is nice too. Adjustable tip on the new wands.
