danny in darketown
got the carb adjusted best i could. i could not move the load needle. letting it soak a while in blaster but i did play with the idle. it was open 2 plus turns. its about 1 and 3/4 turns now, if i turned it back any more than that it would die out and after adjusting the clutch, 2 castle positions on each, i could take off like you said in 6th gear. then when i got it warmed up i changed the oil. saddened when i seen what came out. water at first, on both the drain plug and the filter and the oil was gray not black. lord only knows how long it was in there. hoping it was condensation and not a cracked block, but that seems like alot to hope for. no loss of water from the radiater??? will keep an eye on that.need to check the lube in the tranny next.
