hyd problem
WVFarmall
I recently purchased a john deere 2350. While using this evening I lost all hydraulics and power steering. Does anyone have any ideas what the problem might be?
(quoted from post at 22:38:00 07/11/19) Drive coupler between pump and crankshaft failed.
Ditto check hyd pump drive coupler. Is hyd oil level at full mark? If so change hyd filter & check/clean sump screen as other posters stated. Does tractor have hyd hi-lo & hyd pto? Does it have a FEL?
Thanks for all the responses. Fluid level is full,no loader, have new filter to change as soon as I can. Pump coupler is good.
Thanks again.
Check the screen in the transmission as well as change the filter, it is on the suction side of the pump and will starve the pump before oil ever gets to the filter.
