hyd problems
Mark Lowe
I have an older (yellow) Case 970 w powershift. Put a new relief valve in a couple years ago and had trouble with hyd system this year. Replaced all the oil at that time. Oil gets hot and will not lift either cylinder or 3 pt arms with a load. Cold, it is fine, hyd oil temp went almost to red zone and even had trouble with powershift going in reverse. My mechanic also has two older Cases doing the same thing and can not figure out what is wrong. Did isolate a problem with using a single action cylinder. Tractor is worthless without hyd and 3 pt for me. It is not used much except for spring and fall. Maybe 50 hrs for the year. Any ideas? All filters are changed each year.
Mark I"m not a case mechanic but IDOT had several 895 and 995 case tractors and they were forever having problems like that. The mechanic where we took the tractors said it was the problem with t6he wet parking brake and wheel brakes wearing out and the particles floating around into the close tolerence of the valves and causing them to stick. The remote cylinder control valve would stick in the raise position and after a couple of hours the 3pt would not work and even the powersteering quit and overheat the trans fluid. On cold mornings when trans fluid is cold and your race the engine exsessive pressure would open the bypass on the filter and all that nasty stuff goes out into the system. There was some other floating valve on the side of the trans that stuck that he had to make a puller from cement anchor.
Sure glad I dont own one I have enough problems with the other colors
We have a case 2096 that worked good for about 2 hours then the oil got really hot if you touched the tran houseing with a bare hand it would burn you. When hot it would lift the front wheels off the ground when you shift or let the cluch out. The hyd where almost dead when hot. We split it and found that some of the release springs that push the cluch packs a part where broke or missing. This let the clutch pack run together and this caused the heat. We used it too long this way did a lot of damage. Wish we had fix this sooner.
Thanks for the reply, tractor behaves just fine driving or pulling, with or without the oil hot. I will recheck the filters to make sure I have them in correctly.
