Anonymous-0
i know they make them i am looking for the tool that you can use to pull your hyd.coupling
togather i am tired of getting full of hyd. oil each time i hook up.and then trying when there is presure on the lines.
can any one help?
If you were to change them to the couplers that either IHC or JD and some otheres use they will go together then you turn the lever to let the oil flow without the mess and they can be bought at any used tractor parts place or from the dealer too. They are on IHC 66 series and up, JD the 10 (3010) series and up.
