Hydralic prime?
Helped a friend pull a Ford 2000 1962 apart and installed a new ring gear. After reassemble, no hydraulics. Attempted to prime pump but to no avail. Any suggestions.
Remove the pipe plug at the front head of the pump. Start engine and run at low idle till no air bubbles come out with the oil.
Put a catch basin under the pump and you can pour the oil you catch back into the center reservoir when completed.
Zane
Is there no flow or no 3pt. You can have flow but a stuck unloader and no 3pt.
Post back after pulling plug to seem if you have oil.
Also, keep in mind ice can plug suction line if the sump is wet...
