Osc27
I have a Int.M I want to put a different pump on because the one on there is only rated at 8oo psi.
I have to pick up 800 to 1100 lbs bales and put them in the barn.I have a pump off a mitsubishi forklift. Can I incorprate this into my tractor?
If someone has some plans let me know.
Adapt the pump to the belt pulley, or PTO. Make sure the rotation is correct. The pressure will be fine, the RPM will be slow on either takeoff. but it will work. A PTO driven pump can be found with less grief, and better output. The only solution integrated into the tractor is a distributor housing driven Pump, but it needs a better gear train on the front of the engine (unless your tractor is mid 51 or newer. JimN
Oh yeah,
It can be done. I used a live pump off of a 400 gas tractor.
Allan
