I have a 1948 Ford 8N front mount dist with ELI and Sherman Step up. Totally rebuilt engine and entire hydraulic system has been rebuilt as well. All new hydraulic pump mechanisms, top lift has new piston( jubilee style), cylinder ram, ram arm pin and gasket. ( Did not replace draft control pin), new complete PTO shaft and housing, 90w gear oil filled to bottom insp plate bolt hole.
Before tractor rebuild the 3 point would lift but bleed off quickly and never reach max height. After installation and careful 3 day process of adjusting top lift from the manual, and adjusting the hydraulic touch control lever and control arm connection to hyd pump intake valve, PTO spins, no leaks from above while running, a 3 to 5 second sequence of BUBBLES raising through fluid above hyd pump, and 3 point is dead in the water gentlemen.
Pressure relief valve tested and also swapped with another.
1) Either my top lift internals are badly worn? or adjustment is super messed up?
2) Or The hyd pump housing is done?, which at 73 years old is acceptable.
Any advice will be appreciated guys.
I have a electrical issue as well if someone is willing.
Thank you
Thank you
