Grass Roots Farmer
As posted a week ago my hydraulics stopped working with the lift arms in the up position. With help from this forum, I have drained the hydraulic fluid and today removed both inspection plates. I found the T- shaped control fork disconnected and successfully reconnected it to the jointed arms connected to the control lever. Moving the lever back and forth does not seem to release the valve. I am thinking I need to move the valve rearward to "open" it. Hand pressure does not seem to work either.
I don"t want to break the fork by using excessive force, but can I use a screwdriver (probably through the large drain hole) to pry the control valve open. Exactly where should I pry?
How far would the valve travel to be in the open position.
If I cannot move the valve, what is the next step?
Thanks in advance for getting me this far. Maybe I will get lucky and fix this darn thing.
