Hydraulic cooling lines missing
RBTXS2
I recently bought a Hydro 70 from an estate sale. It is missing the metal lines and hoses that carry hydraulic oil to and from the hydro unit and the hydraulic cooler in front of the radiator. It has a short jumper hose across the two metal fittings under the fuel tank on the belly of the tractor. Could anyone post a picture of what this set of lines/hoses looks like and how they are routed to the cooler up front. The hanger brackets are also missing. Where do they bolt on? Also, is there a bracket on the rear that holds the toplink when not in use? A picture of that would be helpfull also. Thanks for any help you can give me.
Sounds like you need a parts book.That will tell what you need to know.While you are at it,get the operatos manual too. The "bracket" to hold the top link is just a heavy 'wire' clip sort of thing.
