Hydraulic couplers
kub6040
I have the regular pain in the butt connector and want to put breakaway couplers on a 706 farmall any help with a part number would be appreciated
Forget part number.Not sure there even is a part number.Go to your closest implement dealer(any 'color') and get a set of 'Pioneer' breakaway couplers.Even TSC etc should have the neccessary parts. They can get you set up. It will be a piecemeal deal,not a 'kit'. A short piece of hose will be needed for each one as well.Whats mekes them breakaway is a small clamp/holder that holds the couplers. The hoses gives it the flex to break away.
Like Delta said.Or you can get the ones that will connect under pressure from a junkyard off a newer tractor. Some thing like the ones off some of the newer Deer tractors with the levers will work that way. Not sure if they still have the levers for the ISO model couplers newer than the 50 or 60 series tractors. Not sure what Fiat is using for them like that. Those off the old Stiegers with the levers are leaking messes.
You need one of these breakaway brackets:
and two of these breakaway couplers:
All generic parts from your local farm and fleet, or machinery dealer.
Do you now have couplers installed on 706 similarly to those as seen in first picture below?
Second picture shows breakaway hydraulic coupler system factory installed on IH tractors of the 706 and later 56 series tractors.
Third picture is diagram from 756 parts book showing the parts for a breakaway coupler system. 706 parts will be the same.
As others have said you can acquire parts, hydraulic elbows and adapter fittings and have hose made to retrofit your 706 to look and function as the original IH factory system. No need to buy new female couplers as the ones on your 706 will work by fitting them into the clamps of the breakaway parts bracket from Pioneer that another reply shows pictured.
