Hydraulic cylinder for mower
bweb
I'm putting new seals in the cylinder for my mower. After assembled should it be filled with oil or just cycle it back and forth when on the mower? It's a double action cylinder. Thanks.
If you lubricated the seals when you installed them, then just cycle the cylinder and then put it on the mower. If you did not lube the seals or at least did not use very much oil then add a small amount of oil.
