Hydraulic cylinder
agonair
I purchased a couple of Oliver cylinders to clean up and use. One had hose and no couplers so it has been exposed to the elements. The ram is stuck. When I removed the hoses water came out. Is it worth it to dump some penetrant in there to free it up or is it junk?
The other cylinder cleaned up and works fine. I have Olivers so thats why I got them.
At bare minimum it's worth cleaning up any trying.If it goes back and forth,doesnt leak or settle/drift,it's good. So unless its compleely junk,a new set of Orings will fix it right up.
I would try to get it apart and take a look.
Being it was open and exposed, no telling what is inside it. Not worth contaminating your tractors hydraulic system.
I have worked them in and out by pulling/pushing with my small Kubota tractor
to work the water out. Put on fresh hoses and go to work.
At least that worked for me.
The inside of the cylinder bore MAY or MAYNOT be chrome plated, same with the piston rod. The cylinder the water came out of I would definitely NOT hook up to my tractor's hyd system. Depends on how old they are.
I used to do a lot of work with a company that specializes in chrome plating the inside of steel, copper, nickle, stainless steel, you name it, also chrome plated cylinder rod bar stock. They even built their own homes to hone the tubing. They were bragging one time I was there, they chromed a 3/4" diameter hole almost 40 feet long. Anyhow, new cylinders are chromed, the only thing I'd use.
