Hydraulic cylinder
Dnelson2
I have a freeman loader and the center cylinder broke. Need to find replacement. No luck so far
32" pin to pin
18 " stroke
2 1/2" bore
1 1/2" piston dia
the problem seems to be the 32" pin to pin.
Looking for new or used any suggestions please
I looked on surplus center, they have a good selection but I see what you mean about the length. Maybe you could use a coupling nut and a short stud to extend a standard cylinder? another option would be to put a stop collar around the rod to limit the retracted length. Also, a machine shop could shorten a longer tie rod cylinder to whatever you want, but it would be spendy!
