Hydraulic filter cover stuck?
LinWI
IH 674, wanted to change the filter, took out the center bolt, but can't get the cover off. Don't have a filter or strap wrench that big.... any ideas?
tap lightly around the edges with a hammer (preferably a small
ball pean) or tap with a hammer and drift punch around edge
should break loose
Hit it with your hand or loosen it with both hands, it is stuck to the rubber gasket.
Put the bolt back in some. Then tap with a small block on the corner where the taper to the bolt starts. It should just fall off at that point. I would refrain from using a hammer directly. The bolt back in is to keep from getting an oil bath when it breaks loose. Be sure to clean the screen in there on the filter. A new o-ring should come with the filter. I don't always change them since they are rather tough to get out.
