hydraulic filter IH 504
yes that baldwin filter will work , here is some OEM / Interchange Numbers: 388080C91, 388080R93, 388084R92, 388084R93, 6439236, 6439365, HF6066, P551196, PF835, wix51469
here is a more bigger list of replacement numbers
AC PF1528
AC DELCO LH4942
BALDWIN PT558
BIG A 92469
CARQUEST 85469
CLARK EQUIPMENT 1804361
CYCLONE PM-489
DONALDSON P551196
FLEETGUARD HF6066
FRAM C7031
GENERAL MOTORS 89034856
HASTINGS HF759
INTERNATIONAL HARVESTER 388080R93
INTERNATIONAL HARVESTER 388084R92
INTERNATIONAL HARVESTER 388084R93
LUBER-FINER LH4942
N.S.N. 2940-00-411-8237
NAPA GOLD 1469
PUROLATOR H10025
WIX 51469
WOODGATE WGH6066
Sorry if this is late, the number should be right there in the listing for diagram it is 386121R92. Clicking it will show availability and price. Sometimes if not an available part a bit lower it shows ..REPLACEMENTS & SUBSTITUTIONS.. then if you click ..View more.. that it shows if an updated replacement is available. How are you viewing the link? If on a phone you need to click the ..View Parts List.. box at the bottom. On a PC it should default to open to view both the diagram and list side by side. From that link you can see all the parts diagrams for your machine. If you are viewing on a phone it is a little tricky. In fact I would not even recommend it your first few times using it. The main issue is the back button will take you back two pages instead of one. Also on a phone you will need to turn it sideways to see the navigation links at the top. The one that says 504 tractor will take you to the page that shows all the parts sections.
