Hydraulic fluid leaking into differential
tractor1955
The hydraulic fluid is getting into the differential if the seal is bad between the two the fluid should neutralize so the rockshaft piston seal must be bad?
With out knowing what you have it is hard for use to help you help your self. Lack of info makes it impossible to tell you what or where the problem maybe
