Hydraulic Fluid
Robert NC
Replaced the seals on my 660. Reset everything. Lift will pick up and then it doesn"t. Looked inside didn"t see any leaks. Doesn"t leak down. Used Tech fluid from Wal-mart says that it is compatible with M2C134D fluid. Is this the right hydraulic fluid? Or did I screw it up.
Thanks Robert
fluid fine.
if the lift works, then suddenly stops then works again.. I'd be looking at a sticky unlaoder not a suction leak.. though it's super easy few second job to verify prime before moving on to the real work of freeign that sticky unloader ( if it is that.. etc.. )
