Hydraulic issues, 1971 DB 885
KJO
Hello all, new to the group. I'm hoping there are some people with DB knowledge, but my issues, at the moment anyway, are with the hydraulics which may not be specific to a specific tractor or model--hopefully more universal. Anyway, so I purchased this tractor being told that everything worked fine and there were no issues at all. I know very little about tractors--drove a few as a kid on farms but never worked on them--and when I checked it out none of the attachments were on it--loader, box grader/mower. The tractor ran and drove fine, so I bought it. The seller delivered it for me with the loader and grader box on and did have some issues with the loader hydraulics but said it was because it was a little low on hydraulic fluid. I said OK, and he left, big mistake.
So, the loader will raise ok but will not lower unless you push in the clutch--which I'm assuming stops the hydraulic pump--then it will lower although not like it should. The really strange thing is when I try to lower the loader with the clutch out--pump engaged?--the loader actually goes up slightly. The bucket won't move at all, either way. The three point goes up when it's started, and I cannot get it to go down, until it bleads down after it has sat for a day or two. Also, the yellow light on the dash for the hydraulic filter stayed lit all the time.
I texted with the seller about the issues, and he said he would see if a previous interested party was still interested and if not then give me a partial refund. He has since ghosted me--big shock, right?
I waited a few days and then I decided to start with adding some hydraulic fluid and it did nothing to help. I then changed the hydraulic fluid and filter. The fluid was full of water, nasty stuff. That helped very slightly but still have all the issues I had before and the yellow light on the dash is still on.
I am now uncertain on what to do. I doubt very seriously I will ever get anything out of the seller and more importantly, I don't have much hydraulic knowledge other than the basics so not sure where to go next. If anyone has ideas or troubleshooting steps that might lead me to the core problem that would be great.
Hello KJO, welcome to YT! Sounds like you took the “uneducated buyer” route. I would suggest you take some pictures of the loader, valves and hose connections this would be quite helpful. Make sure you include sort of an overall view of the whole machine from each side. For one knowing if the loader is operated by original factory hydraulic remotes generally used to operate hydraulic cylinders on equipment behind the tractor. Or if the loader has its own valves.
As used red has said pictures will be a big help. Most likely the water in the hydraulic oil has caused corrosion in the valve body, and the spools are not working,, at least enough to operate. The pictures will tell us if the loader has the control valves or it uses the tractors. By your description of problems, my guess is the tractors value body needs cleaned and rebuilt. You will need to get a parts breakdown manual and a service manual to show how it's put together and part numbers, along with repair guidance.
Thanks for the replies. One of the first things I did was to download a service manual, thought it might help troubleshoot the problem. I may need to try and find something else that has better parts brake down of the valves though. I had thought the valve body would be my next item of interest as well, thinking the water in the oil has gummed things up or worse. However, doing some research last night my selector lever (3-way switch) I believe is in the left position--the pointer part is broken off--and I'm thinking it should be in the middle? So, I need to try and figure that out. I did read that you need to push the control lever all the way back compressing the spring to turn it. I'm assuming the tractor should be running for this? It's raining pretty good here today so when that decides to break, I will go check that out and get some pics. Thanks again.
It doesn't need to be running to change modes(assuming you are talking about depth\Height/TCU function). This it not your "3 way valve", that is a totally different item, which you may not have, depending on how the loader is plumbed. Pictures will help. The center position is "Height" which is the right choice for most uses.
I have encountered your symptoms before, seems like the selectomatic spool valve was stuck in lift , and the tractor was using a power beyond block to power the loader. It has been a while though.
Great news--my selector lever (pic) was in the wrong position and when I placed it in the correct position things worked as they should. Now it seems the power steering is not functioning quite right and that fluid needs changed though. I will also need to decide if I'm going to keep it and try and fix all the other problems over time or sell it--and try to get most of my money back--and get one in better overall shape. At any rate, thanks for the suggestions and offering to help.
There should be a filter in the power steering reservoir. It has probably never been changed(I think wix makes it). That and low oil levels are about the only problems I have had with those systems, aside from leaks.
If steering seems hard, check your tire pressures, and grease the front end.
