TrustyRustyTractor
We have a 4520 with syncro-range transmission.
The hydraulics started to chatter. I've been reading through some old posts here and it seems to be a common affliction that could have multiple causes.
I'm hoping to post the exact symptoms and everything we have done so far and maybe someone on here can help narrow the focus.
First, the hydraulics work beautifully upon initial start-up. But after the bucket loader gets raised up and down about a half a dozen times the arms start to slow down and things start to shake and chatter. The 3pt. arms will shutter too when you try lift them. Of course, push in the clutch, and as soon as the tranny pump stops pumping, everything comes to a dead stop - instantly, and nothing will even try to move at all until the clutch is let back out again.
Now, we've been on the phone with our local JD dealer mechanic/technician. We have cleaned and inspected all screens and the filter. As instructed, we removed the housing by the filter with the 4 valves in it and made sure they were free of debris and working properly.
Next, They made us do a simple transmission pump test by breaking the line leading to the front pump and turning the engine over. As soon as we releases the clutch, oil came flying out of the line and quickly and easily filled a 5 gallon pail in the time suggested.
So then, they told us, well your front pump must be shot, so we laid down 1200 bucks for a rebuilt one and spent a whole day installing it, but it still didn't solve the problem.
What else could it be? I've read in other posts of there being other "check valves" Where exactly are they?
I also should mention, that the remote the loader is plugged into was recently rebuilt, but the other remote is wore. It can leak badly (on and off) and there seems like there is always a lot of power/pressure going to it even though the console lever is in neutral. Could this alone cause the whole hydraulic system to fail?
Thanks for any insights.
