hydraulic leak
Sam Kroll
I have a 66 Ford 3000, gas 4speed that is leaking hydraulic fluid. I use the mineral oil from Tractor Supply that is designated for Ford tractors. Is there a product I can add to stop or slow down the leak? Thanks.
hydraulic leak
Stop leak products for th most part will work but are usually a short term fix. They work by causing the leaking seal, (along with most others) to swell u which closes the opening. If you give more details of where it is leaking from you may get help with a permanent fix.
