Mortyouery
For years now my 47 8N has exhibited "issues" with the lift function. Current symptoms: intermittent action. I raise the 2 row planter, drive to the area to plant, make a pass of 1200 feet or so, go to raise planter ... won"t lift. Disengage PTO, lower quadrant lever, rev engine, engage PTO, repeat.. nothing. Adjust leveling link....begins to lift.. move tractor forward... planter lifts. Head back to barn, planter drops slowly ... lower quadrant lever...raise lever ...planter raises up.Repeat 3 or 4 times under way. Get to barn .. lower planter..dump hoppers...raise planter..cell phone rings, climb off tractor...conversation lasts 3-4 minutes...planter stays fully raised. Climb on and head to another field ...planter drops slowly.....repeat. A real pain in the arse.
I had a shop look at the lift function a couple of years ago owing to similar symptoms. They said they removed trash from the pump which did seem to help for a while. Anything I can do short of pulling and rebuilding the pump? Not sure I"m up to that. Hydraulic oil is proper level and looks fine. Here"s a pic of the sunflowers cultivated Saturday.
