I recently did a replace of most hydraulic components. When everything was put back together the hydraulics are serverly out of adjustment. The hydraulics will not lower until the control lever is an inch from the bottom of the quadrant. The yoke was tightened until there was no movement in the spring and it only moved the position up about another inch. I have also tried adjusting the quadrant by loosening the four bolts and it doesn't allow for much adjustment. We checked all the internal components and it all appears to be hooked up and working properly. Anyone have experience with this problem after doing a rebuild on hydros?
