Hydraulic lift system.
Duh!! I am just getting it. I realize that the actual pump is on the side of the block. The system under the seat is the valve lift system. Correct? So how many wear parts are there that can be replaced?
Terry
Sorry, it was an impulsive post. My 660 3 point hitch will raise properly, but after an hour of use it drops and won't raise. I was told here to remove the PTO lever plate and see if I can see leaks and I plan to do that. In the mean time I realized that the actual pump was on the side of the block. So, there are fewer parts to replace in the valve system under the seat. I was wondering what they were because when I tear it apart, I want to replace it all.
Terry
Most if not all those parts come in the top cover gasket set. I just rebuilt the 3 point on an 860 and the gasket set if the same. I would start by checking pressure in the system both hot and cold to see if maybe the pump is getting weak
