Hydraulic Lift video
This is a "grainy" video of my lift with an implement on and lifted.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i226.photobucket.com/player.swf?file=http://vid226.photobucket.com/albums/dd98/seeya_later_gator/09-03-07_1030-2.flv"></embed>
This is a video of my lift with the implement on the ground and fluid spraying from somewhere above.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i226.photobucket.com/player.swf?file=http://vid226.photobucket.com/albums/dd98/seeya_later_gator/09-03-07_1028-4.flv"></embed>
So, if you use your imagination, you can tell in the first video there is quite a stream of fluid coming down from the top falling down onto the PTO shaft. In the second video on the left of the screen you will notice a splashing area of fluid. Where is that coming from? Is that normal? My main question is, what part does it look like I need to buy to fix this? Just a ram cylinder piston ring? ( I have the one groove piston in there now) or something else?
(quoted from post at 11:49:06 09/05/07) So, if you use your imagination, you can tell in the first video there is quite a stream of fluid coming down from the top falling down onto the PTO shaft. In the second video.....
Sorry, Seeya, but my imagination must not be very good. I can't tell a darned thing in the first video and the second one doesn't show up at all.
I can see were one of these would come in rite handy to make that call your self.
Telescoping Mirror
