Hydraulic lift
TRS
So I can move the three point up and down by hand. What's the first point to check to begin the process? All the numerous bolts look intimidating to start messing with after 80 yrs. It's 1940 9n
I have a '41 9n that had the same problem. On mine,the fork that moves the pressure valve let go and wasn't attached.With much
trouble,I put it back on. It has happened again,so I'll try some wire to keep the forks together. This may or may not be your
problem.
(quoted from post at 09:27:22 06/25/23) Has it ever worked for you?
Yes, it used to hold mower up and now has zero ability to lift any weight. I assume I just need to start with the inspection panel and see what's happening inside and go from there.
