Hydraulic line clamps
SVcummins
Could not find any of these locally even called hydraulic hose and repair shops I might as well of had 3 heads half didn?t have any idea what they are the other half could Probably find the end of the rainbow but not these . Stupid shipping cost more than the parts but I need them
McMaster-Carr also stocks these same parts in many different sizes. That shipping cost seems really high - I've bought from Surplus Center before and didn't think the shipping was more than $15 or so for packages that would have been much larger and heavier. Was this for next day, air-freight delivery?
This is 3rd day air so it?s a lot more . I originally ordered them a week ago but the card never went through
I really wants to go through surplus center they have spent me catalogs since I was in middle school and I?ve only bought from them a few times . Did anyone else order catalogs like this when they were in school or am I the only one ?
I live about 20 minutes from Surplus Center. It's always a fun place to browse in. Seems they always have something new. Also a very friendly and knowledgeable staff.
I dont think it would be that hard to make some thing like that out of wood--- even if it just had to hold it until some thing else turned up.
When I was in school Surplus Center didn't exist.We used to get the old Central Tractor catalogs and the Sears Roebuck Farm catalog after Sears separated it from the
the main catalog.Herters was another great,very interesting catalog they sold gun parts.
Unless you are stuck on having that style of clamp go to a hardware store or electrical supply and get some of the clamps they sell for tech cable.
Plastic coated aluminum, strong,easy to work with, available in many sizes and a whole lot cheaper.
2 clamps, one screw or bolt in the middle and you're done.
if I would known could sent you some for the freight I still have lots new parts and pieces left from when I used to assemble new farm equipment in my shop, you would not believe the stuff you get sometimes. planters, tillage tools ,rippers, grain augers usually over 100 a year
I thought it actually wasn?t to bad of a price even with shipping . Sometimes it?s just as easy to buy the part as trying to make it . Your right the wood could prove pretty hard to weld
I?ve always collected farm catalogs there use to be a catalog called modern farm it would come a couple times a year . They had a set of wrenches that could split nuts and also had a deal that you could use like a wrench to for nuts you didn?t want to split
The parts you are ordering are plastic --you wont be welding them either . There is a bolt that goes through and you either have to drill and tap a hole or in some cases they weld the head of the bolt to the frame and then assemble. On top is a 1X2 1/2 metal strap with a hole in the center , below that is the plastic body in two halves that you put on both sides of your hose or hydraulic pipe. The plastic body was what I thought you could have made from wood -- the strap I am sure you could have made from scrap. Other wise go with the electrical conduent clamps -- easy enough.
I have always found Surplus Center's shipping high on smaller items. I always try to stock up on small stuff like those clamps when ordering something larger.
For anyone who hasn't used those, they are the cat's azz, weld on back plate is a nice touch.
Jim
The bolt goes through the plastic halves into a threaded hole in the back plate. Weld the back plate where you need it and then assemble with the hose in place.
