Hydraulic loader control Ford to Case
Jim Faust
My son is refabricating an old Ford loader that had an external hydraulic pump to fit on a Case 630. How does he hook up the tractor hydraulics to the two lever loader control? I'm thinking he would hook one hose in to the controls and have to install a fitting to return to the tractor instead of using the old external oil sump on the loader.
Thanks,
jf
Yup. However- do you know the cyl pressure? Did Ford have high pressure cylinders and your Case is lower? If so, your Ford cyl will take the low pressure but lift less weight due to less surface area on the piston.
