Reference #16 on the 75 tips, I was running my 52 8N just to warm it up (can't stand to let engines/machinery just sit for extended periods), and lifted the box blade a couple of times, holding for a few seconds, just exercising it in general, and noticed a new oil leak from the top cover under the seat in front of the draft control lever. It leaks only when the lift is engaged, and while it isn't a high volume leak, it is a constant seep directly under the hump between the 2 front bolts. I am a former 8N user/owner (~50 and 30 years ago), I don't have any experience removing the top cover and getting into the hydraulics, and before I jump off the deep end, I am soliciting any suggestions as to course of actions before I begin at the end and wind up with a lawn ornament? The oil is very clean and relatively thin and doesn't look like 80-90 wt gear oil - could that be a factor? Need to get this fixed before 100 deg weather hits! Thanks in advance.
George J, Sumter, SC
"Lift a heavy implement & look inside with the tractor running & the PTO engaged to see if you notice oil running from the top cover. If oil is running steadily from the top cover the chances are the lift cylinder needs to be rebuilt. It's less likely, but a possibility, that the top cover gasket is bad. (It's very difficult to detect the exact source of the oil leaking inside of the top cover while looking through the inspection port)."
[/img]
