Hydraulic oil transfer pump
Need to find the hydraulic transfer pump for my 2020.
the main pump is good but does not seem to be getting
oil to it from the rear. can not find a part number for the pump,
any ideas?
You would be wise to get a factory shop manual and go through the troubleshooting procedures for the hydraulic system BEFORE throwing $$$$ parts at it. If it has a reverser or a hydraulic "hi-lo" there's lots of places for internal leaks that affect how much oil is left over to feed the main pump.
As the as the pump is concerned, go to the link below, enter your model number, open PC0971, click on the "transmission" section, and look for "transmission pump".
There's more than one part number, depending upon if you have a hydraulic hi-lo or a reverser, or a plain transmission.
JD parts
does not have a reverser
screen is new
oil changed
do you know of the pump I'm talking about?
the main pump up front is new
we are breaking the tractor in half this week, I guess no one
else has came across this problem ?
thanks again
Take it apart first and inspect everything. Pay close attention to the oil tubes inside to make sure they were in place and not damaged/rubbed through. One cracked tube and things don't work right. Good for you determining the main pump is good before just replacing it like a lot of people do.
So, did you find it on jdparts?
<img src = "http://jdpc.deere.com/pimages/RWP2/RWP2328________UN01JAN94.gif">
Pump should be put together using thin film of anaerobic
compound (sealant).
Good pumps sometimes won't work without it.
"is that the part number RWP2328 ?"
That is the drawing number, I told you how to bring up the parts catalog on jdparts.com to look up the correct part number, need serial number as well as transmission type I mentioned before, and I hon't have the serial #, so I can't look it up for you!
Bryan
If you tractor doesn't have hyd hi-lo then pump &amp; associated parts shown below should fit your 2020.
