Used to work in plumbing. That’s why galvanized ain’t used for nat gas either. What would matter the age of the tractor? Tiny flakes of zinc respects no age. I am new here, just saw this thread. Thought every farm boy knows about galvanized. (Also, unless you got great insurance and a loving fam, DO NOT WELD GALVANIZE!!) Ask any professional welder or Google. Whew!Have you ever looked at pressure rating on Gal. and black pipe and you never want to even think about gal. pipe as the gal. can flake off and go thru the pump if it does not explode first and this pipe you now get at Lowes / Home depo / Mansards is made in China and it is really not even good for air pressure anymore . So stop and look up sch 40 black pipe rating . Ya want to run Hyd pressure then use Hyd tubing and fittings made for the pressure , one thing you never want to get hit with hyd pressure and when looking for a high pressure leak NEVER NEVER use your hands , use a piece of cardboard .
I have never and shall never run a HYDRAULIC pressure line with galvanized pipe or black iron pipe.Anyone use galvanized pipe or black iron pipe for hydraulics? I have some hydraulic hose her but it's a bit short so I was thinking maybe run a pipe from the elbow coming out the tractor to the rear end then hose from there. What do you think.
It's not a problem, until it is. Good USA made pipe and fittings from back in the day, sure. This offshore stuff that you get these days? Not sure I'd trust it with any more than water pressure. I've gotten brand new fittings with pinholes in them right out of the package.I've used common pipe for years on hydralics. Never had a problem. IH letter series,x00 series,06/56 series.The max pressure on those is under 2000 psi.
