Hydraulic power beyond conversion
I'm in the process of adding a couple Prince remote controll hydraulic valves on to my farmall SMTA. I ordered a "power beyond" conversion along with the valves so I can install them in line with each other. The problem is that I have no idea where the plug goes. No instructions came with either the plug or the valves.
Thanks for all the help
Ben
The power-beyond plug goes in the normal return plug. Then your new return line goes to the other return port. You can tie the 2 return lines together after the second valve. Never did a prince but that is how a Commercial and a Gresen are. You must have 2 ports on the outlet side. Do both of these valves have relief valves?
There is an additional return plug on the end of most Prince valves. It goes there. You still need to connect the return on the top to the reservoir.
