hydraulic problem----hydraulic remote????
james9n
i have a case 1175--i used a disc the other day. It raised and lowered like it should although toward the end i was thinking it was getting slow and also i didnt fold the "wings" of the disc up/down etc...just raised it and lowered it as a whole. Today i go to use it, folded it up, raised it up and on my way. About 100 yds away the disc lowered down and will only make a weak attempt to be raised....yet using the same lever it seems to activate two separate cylinders to some degree. While lowerering(maybe raising i forget) the wings will try to lower a little bit as well....all while using one lever.---can someone explain to me whats going on? If its the hydraulic remote can it be rebuilt?
If everything was working normal, the hoses must be connect properly. Things do act goofy when hoses are not paired up correctly or having a male and female coupler that are not matched. That would only leave the valve at fault and yes they can be rebuilt.
