Hydraulic problems on Ford 1720
cgbum
I am working to repair the hydraulics on a 1988 ford 1720 with a front-end loader. The tractor had been sitting because the bucket would not raise.
Hydraulics work intermittently.
Fuild is full, but a paper towel was stuffed in the fluid fill hole. It appeared to be falling apart. I plan on changing the fluid and filter. Are there any tricks to remove water or paper towel trash that may have gotten into the system? Will the fluid change fix the problem?
Drained the fluid. Got 12 gallons of milky fluid out. The filter was a real pain to remove, but I got it! Put seven gallons back in per the specs. Works like a champ. I plan to use it for an hour or 2 then change the fluid and filter again. Should I be worried about long term damage from the water that sat in there for maybe a year?
