I was pulling my cultivator with my TEA 20 and I lost lift. The arms still lift but cannot sustain the pressure to lift an implement, I can even move them down slightly with my weight. I just replaced the cylinder and the piston is in good shape. When I had the lift cover off some water got in the oil I think because it went all milky. I pulled the inspection plate and there is no leakage from above as it tries to lift the implement. There is however turbulence around the pump. Is this indicative of a failed PRV? Can I remove an replace it from the side covers or should I pull the pump? I also checked the control valve and it is not sticking or anything. Thanks for any input.
