Hydraulic pump - 1982 7710
4500GUY
Hi Guys,
Did a lot of work to my 1982 Ford 7710 with help from folks on the forum here.
Had a question about the gear driven, hydraulic pump on the transmission. Can these units be rebuilt? What is a good pressure test procedure?
Thanks!
- Dave
Usually the housing is worn out so that even if you could find the gears, it still would not perform as needed. So a replacement unit is recommended. A worn unit might test high when cold and then quickly drop as the unit warms up a bit usually in a just a few minutes of running. Some 7710s have the mega-flow option with dual (two) pumps on them, one on the back of the engine as well as the transmission pump. IIRC the pump is spec'ed at 2500 lbs
(quoted from post at 16:49:38 02/08/22) Usually the housing is worn out so that even if you could find the gears, it still would not perform as needed. So a replacement unit is recommended. A worn unit might test high when cold and then quickly drop as the unit warms up a bit usually in a just a few minutes of running. Some 7710s have the mega-flow option with dual (two) pumps on them, one on the back of the engine as well as the transmission pump. IIRC the pump is spec'ed at 2500 lbs
Yes, I was afraid of that. The symptom you described about pressure when cold and lowers when hot is what I am experiencing. My 7710 has the (2) pump set up.
I will look into replacing the pump.
Thanks for your insight.
