Hydraulic pump casting cracking
What could be the reason for pto hydraulic pump casting cracking?
It drives a flail hedge brusher
The owner had it welded but not successful
New pump now fitted at cost of 1100
I am in uk
No photos available only going by what I been told
I was thinking if theres a problem in the line somewhere
Could it happen again
Start by checking system operating pressure. If it broke through the ports it sounds like fatigue from repeated shock loads. Had a Abex vane motor that continuously blew the shaft seal... really, really expensive shaft seal...hydraulic shop didnt know what to do , manufacturer didnt know what to do.... I lowered the relief pressure to just a little over what it had to be to do the job, probably 2/3 of rated working pressure, and didnt have any more trouble with it.
Without seeing it impossible to know, but could have been defective material or machining, something passed through and jammed it, excessive pressure, overtightened plumbing fitting, improperly mounted...
