Working on a 2N and found the crossbar and 1/2" of the valve with cotter pin laying loose behind the pump. The lift worked if I worked the valve in and out by hand. Went out later to pull the valve, and only the spring was sticking out. The valve apparently sucked into the pump. I tried a magnet, and a wire hook, but no luck. It seems to be in there a ways. Do I need to drop the pump? When it was out, it slid easily and wasn't binding or tight at all. I wondered if I put fluid back in and fired it up, if it would come out, but I don't want to have it go anywhere I can't get to it.
This post was edited by arnold z on 08/15/2023 at 02:56 pm.
