Hydraulic pump help
jonchip
Is there a chance that someone might know what kind of pump this is? I have a 51 8n and the pump is from a Dearborn 19-8. I found the pump for the 19-8 but it is a little
different. As you can see from my pics the back is solid. And the original looks like it had a bolt or drain on the back. Sorry I don't have better pics but I thought I would
be able to find something with all the numbers it has on it and only took close ups.
(quoted from post at 04:42:59 01/03/18) Is there a chance that someone might know what kind of pump this is? I have a 51 8n and the pump is from a Dearborn 19-8. I found the pump for the 19-8 but it is a little
I do not recognize the pump. What are you trying to accomplish by identifying it?
TOH
The pump works great but leaks out the front shaft seal. So I was wanting to know what pump just to make sure I order the right
seals or if they are even available.
(quoted from post at 15:26:01 01/03/18) The pump works great but leaks out the front shaft seal. So I was wanting to know what pump just to make sure I order the right
On a pump of that vintage shaft seals are pretty generic. Disassemble, measure the seal, and order based on size. If the seal leaks there is a good chance there is a mechanical reason behind it - e.g worn shaft and/or bearing...
TOH
